Profile Data Report
Profile Data Report
Is there a way to export Profile Data from a profile view band? I want to export data showing "Profile 1 minus Profile 2", that would give the thickness of a rock layer in text format.
Jeew-m
Dear friend,
You can find this in report manager in tool box tab.
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/documentation/CIV3D/2014/...
Thanks........
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
The problem is that report works only with layout/designed profiles. Mine are exciting profiles! I was thinking about using panorma/profile Grid view. copying elevations for stations to excel and doing a subtraction. The only problem is that stations are taken randomly or am I wrong? I want elevations taken at same stations so I can subtract them!
Jeff_M
@Anonymous, the report @Jeew-m suggested does exactly what you are asking for. When you select a Design profile the existing profiles are then displayed (they should automatically display since the first design profile is pre-checked, but this is not the case). Note that I have selected both a Design Profile AND a surface profile:
You will get a warning that no static existing profiles found, do you want to continue....hitting either Yes or No still allows the report to be created with the selected profiles. So that is a bug, but you still get the desired report.
