I'm having problems with cross sections. As you can see, the cut and fill hatches are exceeding beyond the surface lines. Appreciate your help!
You are comparing two surfaces so its warks as intended.
If you want to find the cut and fill of a specific area you need to define the boundaries of it.
What excacly do you want to acomplish here?
Hello sir, i was trying to get the cross section for cut and fill, i already set the boundaries of my corridors, but keep getting this drawings generated, the cut and fill hatch is still extending beyond the existing ground line.
Hi Michael,
Welcome to the forum!
It sounds like there might be a couple of issues affecting your cross sections, such as the sections not displaying the entire section or the corridor boundary not being captured correctly.
To better assist you, could you please share the DWG file or more screenshots, including a plan view? This will help us understand the issue more clearly and provide you with more targeted assistance.
