I have a problem with the scale of the cross section in Civil 3D. I am using the 1 :1000 but it is not showing properly on the layout. Although, it seems fine in the model.
Could you please help me with that?
Thank you.
Thank you.
I have always thought that cross sections should be in a dwg file by themselves. Do you have model space and your layout set to the same scale?
Since I never use Metric, I have a little trouble getting into it. I would think that 1:1000 is too large of a scale.
Bill
Bill
Thank you very much for the answer. Maybe I need to elaborate more. On the model, the numbers look fine on the y axis. While on the layout it is distorted. How can I fix that? I thought it may be related to scale. Maybe it is not.
Post your drawing.
Post your drawing.
