Problem with Surface Elevation Labels when I use them in another file as an External Reference (Xref).
jessica.guerrabeltranLKQYP
Message 1 of 8
Hello to everyone,
I have a problem with my Surface Elevation Labels when I use them in another file as an External Reference (Xref).
When I set background mask to my Surface Elevation Labels on my original file, the file where I have the reference does not take the colour that I desire (white) but instead takes the colour of the layer of the text with the elevation (red).
How can I fix this problem?
Picture 1 shows the Surface Elevation Labels in the original file. (as I wish)
Picture 2 shows the Surface Elevation Labels in file with the External reference.
Picture 1
Picture 1Picture 1
Picture 2
Picture 2Picture 2
Replies (7)
Message 2 of 8
AllenJessup
Can you show us your Surface Elevation Label Style please?
Allen Jessup
CAD Manager - Designer
Message 3 of 8
Joe-Bouza
What if I told you you could Dref spot elevations and never had to chase a xy position again?
use a pipe network structure styled as a spot grade and never worry again
Joe Bouza
Message 4 of 8
TJMaust
Make sure you have VISRETAIN turned off so your xref is controlled from your 2nd drawings layer manager.
What layer is your Xref on? is that layer color red? what do the xref label look like if you change the xref to a different layer?
Message 5 of 8
AdammReilly
Are the labels on layer 0 and is your xref on any other layer that might have some different settings applied to it?
I've seen where some objects within an xref that are on layer 0 will inherit settings from the layer that the xref is on. This shouldn't be the case here, but it's something to rule out.
Adam Reilly
Civil 3D 2026
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Message 6 of 8
Message 7 of 8
VISRETAIN is 0
My Xref is on a specific Layer that I created for the reference and the color is white
I have changed xref layer but they still look the same
Message 8 of 8
TJMaust
Does it still look like this when you pull the label out into a dragged state?
