problem with profile data
i need to solve a problem. I created a road profile and i get data of elevation of terrain. Then i created a road and i do not get data of a terain of the new road. In table data for existing terain i put elevation 1 , and for data for the road i put elevation 2. But i get data the same. Look the pictures, regards
Jeff_M
@Anonymous, please do not post Word doc or docx files. Many people will not download/open them due to security concerns. Instead, just attach the images directly to the message.
You need to set the profile1 & profile2 in the Profileview Band settings:
Jeff_M, also a frequent Swamper
Jeff thanks for the solution, but is not working. Now i send a file, if you can fix that problem. Regards
redtransitconsultants
I believe the issue you are having is that the band data you think should populate at that location is a Profile Data Band Label and not a Section Data Band Label. I see your sections are placed in plan view and most appear to be on station which is why the stations line up in the band data, except this one section is at an odd station - this particular piece of band data will not work on the section data.
An alternative way to make this populate is set up the style to also label station equations and place a station equation on the alignment at that sections location. It is not ideal, but should help populate that station data.
Hope this helps.
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Tnak you, but i do not need data for proposed station, i need it for proposed elevation. How to do that?
