Problem with Corridor and Subassembly composer
lunhatduy92
lunhatduy92
Hello Everyone. I have some problems with SAC and Civil 3D need your helps.
1. I want to create geotextile in SAC, but in superelevation case, it wasn't run correct. I use "Angle and Distance", was set reference point, set Apply AOR for it.
2. In the curve, If I set target BMTN surface(Existing Ground) then the road can't run (in case cut the BMTN (Existing Ground)). in the straight or not set target BMTN is ok.
3. The existing surface don't show in some crossection views.
I check my surface, it is fine. but in some crossection it can show correct.
I will attach my files below. The SAC of road is "DUONG_SONG KINH.pkt", Existing Ground is "BMTN" file. Many thanks for your helps.
Mike.M.Carlson
Instead of trying to use the Apply AOR check-box and an angle and distance point type for P21, try to use a Delta X and slope point type.  This point will have the Delta X whatever width you want the geotextile, but the % slope will have an expression like L19.slope or whatever link controls the superelevation % slope designation.  This way, whatever the superelevation % slope is for the controlling link, you can correlate the geotextile links to match that % slope.  I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
lunhatduy92
Many thank for your help. I want the width of the geotextile is 1m. so if I use Delta X and slope point type the width of it will not be 1m, and if i want to change this value to another value it will be harder.
taophatxit
1. Các AOR có vẻ hay bị lỗi, bên mình thường hay lấy giá trị trực tiếp từ siêu cao! Bạn xem tham khảo ở topic này
https://forums.autodesk.com/t5/civil-3d-forum/subassembly-composer-define-variable-width-for-superel...
2. Vấn đề này tôi nghĩ vẫn là do siêu cao và AOR! AOR thật sự chạy hay gặp lỗi! Tôi test thử support SE = unsupport (tắt siêu cao ở Assembly) thì lane chạy ra bình thường!
3. Cái này tôi đoán bề mặt của ông có vấn đề! Ông có dán các bề mặt chồng lên nhau không?
lunhatduy92
2. Lúc đầu mình cũng nghĩ là do siêu cao, cũng thử unsupport nhưng có lúc nó vẫn bị lỗi, sau đó mình mới thử bỏ target thì nó lại bình thường.
3. Surface này mình DatashortCut 1 surface thôi nên chắc không trùng, nó bị cục bộ vài chỗ chứ không bị hết toàn bộ tuyến. Khi kiểm tra file gốc thì không hề bị lỗi.
taophatxit
Tôi vẫn nghĩ chắc là do cái AOR! Tôi bỏ không dùng nó lâu rồi! Ông thử lấy sửa cái siêu cao theo cách tôi đính kèm ở link trên xem! Có thể nó giải quyết cả 2 lỗi 1 2!
Cái lỗi 3 hơi dị! Tôi chưa thấy bao giờ! Nhưng chính tôi vẫn nghĩ do bản thân cái bề mặt của ông có vấn đề thôi! Ông thử xuất trắc ngang ngay tại vị trí lỗi trên file gốc surface xem ntn (giống như xuất trắc ngang tự nhiên ấy)
Tiện tôi đang nghịch cái inventor để làm hố ga cho C3D nhưng bị lỗi! ông có biết khoản này sang sup tôi tí!https://forums.autodesk.com/t5/civil-3d-forum/error-when-export-ife-to-c3d/td-p/8744815
lunhatduy92
cảm ơn ông nhiều nghen, để tui chỉnh cái vải địa theo link ông gửi xem sao. còn cái bề mặt lúc xuất trắc ngang trên file gốc thì ổn hết, hông bị sao hết mới đau đầu chứ. Còn inventer tui chưa nghiên cứu. hihihi
