1/7 메시지
Problem with Corridor and Subassembly composer
Hello Everyone. I have some problems with SAC and Civil 3D need your helps.
1. I want to create geotextile in SAC, but in superelevation case, it wasn't run correct. I use "Angle and Distance", was set reference point, set Apply AOR for it.
2. In the curve, If I set target BMTN surface(Existing Ground) then the road can't run (in case cut the BMTN (Existing Ground)). in the straight or not set target BMTN is ok.
3. The existing surface don't show in some crossection views.
I check my surface, it is fine. but in some crossection it can show correct.
I will attach my files below. The SAC of road is "DUONG_SONG KINH.pkt", Existing Ground is "BMTN" file. Many thanks for your helps.
