The problem arises when you use an assembly like this:
1. a basic lane both sides.2. a BasicSideSlopeCutDitch both sides
Then you make
1. A corridor using this assembly. 2. Then create the corridor surfaces, 3. Calculate the earthwork, 4. Draw the sections 5. Create a report of the earthwork
When you chek the report, you find some sections that have no cut nor fill calculated (they appear as zero (0), When you look at the drawing of this section, you find that the section shows a closed shape, that is, THERE IS A CUT AREA AND A FILL AREA. However, the report shows them as zero.
I solved the problem this way:I added a ConditionalCutOrFill at each of the cut or fill branch of the BasicSideSlopeCutDitch (there are four branches; you add four ConditionalCutOrFill. When you perform th steps 1 to 5, and check the report and the sections, you find all the sections have cut or fill.as it should be. The problem is solved.
