problem to chose my countries datum-KosovaREF01
Hello I am a user of auto desk but I have a proble using a datum of my country KOSOVAREF01:    THIS DATUM IS NOT ON THE LIST OF THE DATUM'S, MEANWHILE ESRI HAS PUT IT ON THE LIST
EX:  AutoCad Civil 3D  2016-> ON TOOLSPACE-->active drawing settings view -<> right click on the name of the drawing ex: Drawing 1 -> Drawing Settings-> Units and Zone--> Categories
then the slide list it is by letter "k":
 kazakhstan,
Kenya,
Kirgistan,
Korea,
but Kosovo is noT There??!!!
ChicagoLooper
Try this:
Slovenia, MGI1901.Balkans-7
sloveniaMGI1901-7.PNG**********************Also, you may do this******************Alternatively, on command type MAPCSASSIGN. Then type 3909 in the search box, select the resulting coordinate system that appears (it will be MGI1901.Balkans-7) and click VIEW at bottom, wait patiently for next dialog then click "-WKT" on the left side panel.
Chicagolooper
It is not working, I typed MAPCSASSIGN than it required the code: 3909
than after enter-> Unknown Coordinate systemcode????!!!
Pointdump
Kushtrim,
Autodesk adds more Projections and Datums with each new release. If your 2016 version doesn't have EPSG:3909, then your options are to upgrade to newer version or create that definition yourself. My 2018 version has 3909:3909.png
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
ChicagoLooper
Here are three options:
1) You can go to Civil 3D workspace=>Toolspace=>Settngs tab=>Right click on Drawing Name=>Edit Drawing Settings. Then in UNITS AND ZONE tab, categories section, change it to SLOVENIA. Next, in, in dropdown labeled Available coordinate systems, scroll to MGI-1901/Balkans zone 7. Then OK to exit.
Toolspace>Settings Tab>Right clk drawing nameToolspace>Settings Tab>Right clk drawing name*************OR TRY THIS***************2) Type MAPCSASSIGN on command line. Then in the search box type in "MGI" (without quotation marks). This will result in a broader search and will display much more matches. You'll have to scroll through the displayed results so look for MGI1901.Balkans-7 and select it. See how >HERE< click.
3) Use a different projection like UTM84-34N (EPSG 32634).
Chicagolooper
