Problem opening 2018 model file with C3D 2021
Message 1 of 23
I get this message when i open my model file. Anyone have any ideas, get the same message when i try to open in C3D 2018.
Replies (22)
Message 2 of 23
You can go forward with versions of C3D but you can't go back.  If this drawing was opened with a newer version of the software you will have to continue the project with the newer version.
Message 3 of 23
It was started in 2018 and i get the same message no matter what i open it with. Project is almost done but can not get in the model to make some changes.
Message 4 of 23
Can you upload the drawing
Message 5 of 23
Here you go.
thanks
Terry
Message 6 of 23
wfberry
I had no problem opening up in my 2021 version.
Audit found no errors.
Bill
Message 7 of 23
This is not your model base file. Everything in this file is referenced short cut. Try opening the drawing where these shortcuts originated from and go from there.
Message 8 of 23
That is the drawing where the short came from.
Message 9 of 23
Did you get the error message also?
Message 10 of 23
See attached, see the little arrow in front of the yellow exclamation. That means that the alignment is a data shortcut. If the alignment was created in that drawing, the little arrow wouldn't be there. The alignments or whatever is short-cutted can only be adjusted in the drawing they were created in.  You can short cut an alignment and use it as a reference in another drawing and cut your a profile or run a corridor. But everything in the drawing you uploaded has the little arrow in front of your items in the Prospector Tab. And no I did not get that message, I am using 2019.
Message 11 of 23
pendean
Community Legend
Community Legend
Message 12 of 23
Try to do a repair of all your shortcuts and see if that helps since you have the directories i don't
Message 13 of 23
None of that is there when i open it. Can you do a saveas of the drawing and post it back.
Thank you
Terry
Message 14 of 23
No, sorry I can't.
Message 15 of 23
That's only his data info from his profile.
Message 16 of 23
Yes i know the info is wrong but i can't find where to change it now.
Message 17 of 23
That's to bad i would like to open the save as to see if it shows up like that for me.  I guess i have no choose but to start over with the model.  The data short cuts still work from the project so i guess i will do that.  You can see the file name is correct for where the short cuts came from.  Will they not let you post the drawing back?  Can you email it back to me or upload to a cloud if i email you a link to put it in?
Message 18 of 23
Jeff_M
@Anonymous I, too, can open this drawing just fine. Open the Xref and see if you get the same message. Do the same for the drawing(s) that the Alignments are Dref'ed from "175040C-SPMODEL-ROAD-SEC7.dwg" appears to be the main one. When you get the message about newer version, close the drawing and start a session of "C3D As AutoCAD" and open that dwg. Use QuickSelect and look for the object type "PROXYENTITY" (I think that's it, or something close to that) in the list of available objects. Select that and OK. Erase the selection set. Save/Close. It should now allow the drawings to be opened in C3D.
Jeff_M, also a frequent Swamper
Message 19 of 23
See the source location, that's where to go.
Message 20 of 23
Another thing I noticed the filenames, the source name is different than the file you posted.
