Problem in Civil 3D: " Something wrong with current subassembly: Object reference not set to an instance of an object. "
oussamakrouma97
oussamakrouma97
I’m encountering an error when using my custom subassembly in Civil 3D. Specifically, when I try to apply the subassembly, I get the following message in civil 3d:
“Object reference not set to an instance of an object.”
The subassembly file itself works perfectly fine in subassembly Composer with all condition .
Photos and the pkt file
113322
camden.n.dean
This happens to me when I don't assign all targets. Sometimes I intended to only allow a target to override a dimension, but I set it up wrong and the subassembly needs all the targets to build itself. I'd double check that you assigned all targets in Civil 3D.
