Problem Exporting Feature Codes using Trimble Link
dsayers68
dsayers68
Trying to export feature codes from my PC to my Trimble Survey Controller.
....I selected "Export Feature Code Library " using the ribbon option Export to Trimble Survey Controller/Trimble Access, then, when I get to the part where I navigate/specify the destination folder on the TCS do I navigate to the trimbledata folder? I tried this and the ok button is greyed-out.
I can import a .job file so, I don't believe it's a connection issue.
Any ideas?
I have the same issue, but I can make it to where it can be saved on the Survey Data Card, then it goes grey.  I try to save it in the Survey Data Card folder to see if it works, but I get a message saying, access denied.
Have you come to any resolution?
