Problem Data Ref multiple profiles from the same alignment
I'll try to keep this simple:
dwg A has the parent alignment 1 and a data ref is created for it
dwg B has alignment 1 data ref'ed in, and profile 1.0 is created and a data ref is created for it
dwg C is created by copying dwg B which already has alignment 1 data ref'ed in and profile 1.0. Profile 1.0 is renamed to 1.1 and revised and a data ref is created for it
-at this point we have two different road profiles or options designed for the same alignment
dwg E is created and the intent is to overlay both profiles so it has alignment 1 data ref'ed in, but only one profile is available at this point to be data ref'ed.
Profile 1.0 is only available to be data ref'ed in to dwg E, profile 1.1 does not show up in the shortcut menu. All dwg's and profiles are named differently. When I double back to re-create the data ref for profile 1.1, it either does not show up, or it thinks it is still profile 1.0 and has a check mark next to it. Furthermore, within dwg E, if I delete the data shortcut (in the short cut menu) to profile 1.0 it remove it and profile 1.1 shows up in its place without me having to add it...what is even weirder is that profile 1.0 continues to show up in dwg E after it was original data ref'ed. Seems like a circular loop is happening where I have to delete one and the other takes its place, but both still have a dynamic link and are able to be synchronized.
