Civil 3D Forum
Problem Building/Displaying Corridor Cut/Fill
5 REPLIES 5
daniel.richter2ZLC9
271 Views, 5 Replies
I have an assembly built, as well as a proposed profile over an existing surface for my alignment. I'm having trouble getting the cut/fill to display properly, my guess is that it has something to do with my assembly being custom. I probably missed a step somewhere, can anyone help out?
Thanks in advance
5 REPLIES 5
Hi @daniel.richter2ZLC9, I hope you're doing fine. I didn't understand quite well where or in which way you want to display cut/fill. Do you mean in section views? profile view? or, are you talking about the daylight feature lines that represent cut and fill?
I saw your file but it wasn't easy to understand the problem, and the PKT is missing so I couldn't regenerate the corridor. Could you please post the PKT?
Have a good day!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
I'm trying to view cut and fill in plan view, the corridor is displayed as some uniform white lines. I posted the .dwg, is there a different way to share a PKT with you? I'm new to both Civil 3D and the Autodesk forums.
Hi! you can attach the PKT here as a ZIP file
Post it and let's see if we can help you. Best regards!
Camilo Fernández
LinkedIn
Ah, here you go.
Hi @daniel.richter2ZLC9, it seems you posted again just the DWG file, not the PKT file with the custom subassembly. But don't worry, if you cannot post it upload a photo of the subassembly composer flowchart, it might help
Best regards!
Camilo Fernández
LinkedIn
Rail Community
