When setting the parts list path for pressure pipes in Civil 3D 2017, the path is supposed to be pointing to a common network drive. Our company has multiple office locations and cad users need to be pathed to the same pressure pipe parts list. The path doesn’t always stay and defaults back to the pressure pipes parts lists on the C drive. Our company uses a cloud base storage system, Panzura. What do I need to do to make the path remain?
Hi jonnymaun,
The path to your pressure pipe network gets stored in the AutoCAD profile. When AutoCAD exits, the information from the profile gets saved in the computer's registry.
Why am I bringing the whole registry thing up? I'm thinking that there are two possibilities.
Let me know if either of these suggestions work! Thanks!
I can have some coworkers check their profiles. I've seen it where, in the same session of cad, the path is set to right location and the very next command is to check the pathing and it has already defaulted back to the C drive. Thank you
Thank you. I work remotely from home with somewhat of an unreliable VPN. I have the catalog on my computer and one other guy in the main office has opened the master drawing, the one with the pp network. So does that mean i need to share the catalog from my computer to the other person using the drawing?
Nevermind, that was meant for a different post.
