How can I add an additional surface profile to an existing pressure pipe run profile. I can't seem to find an add surface option similar to pipe network profiles. Wanting to add existing surface to profile. Thanks.
Solved by chriscowgill7373. Go to Solution.
pressure pipe runs have an alignment. If you want to add a surface profile, utilize the same methodology, start the Surface Profile tool, select the pressure run's alignment, and then select the surface you want to draw in, as well as the style. It will add it to the profile view automatically.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Perfect. Thanks.
