Pressure Pipe Network Creation
Hi everyone,
This issue is especially occurring when I create a "looped" network. When starting a network study in the plan, everything seems fine. It starts from somewhere I picked in the screen, then creates elbows, continues; however, when I click on the pipe to close the loop, it doesn't create the elbow or tee.
I have recorded a screenview.
Is there anyone who can help?
lim.wendy
Hi @Anonymous ,
Thank you for reporting this and sharing this. I've escalated this to the support team. You should hear from them.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Topmig
Hi @Anonymous ,
You are connecting point 1 directly to point 3, and that seems to be a depression on point 2, so the pipes doesn't connect.
Because of that, it seem's that the TEE is not working well
Put the TEE in the rigth place manually.
See attached
Thank you for your reply. As our understanding, the pipe catalog doesn't work properly.
Actually we are adding tee manually too; however, piperuns detaching from the profile.
If we add the fitting manually, then save and re-open the file, the piperun seen as detached.
Thank you for your answer.
Regards.
