Pressure Pipe Labels in multiple section views
Thomas-Glidewell
Message 1 of 8
Thomas-Glidewell
I have an alignment with sample lines that are sampling a couple pressure networks. Sample set at 50' increments. In the section views it is showing the pipes correctly. But the issue is if a multiple section views are showing the same pipe at different locations along the alignment the pipe can only be labeled in one of the section views.
C3D 2023 all updates and such applied.
Thomas G
Replies (7)
Message 2 of 8
v-silvestre
Instead of using a Pressure Part Profile label, you could use a Profile View Label.  Granted it's not ideal and a little more work, you should be able to the annotation you want.
Message 3 of 8
Thomas-Glidewell
Agreed but that as you know takes away from the dynamic labels which change as design changes. Using profile view labels would definitely lead to incorrect data in the plans since they are static to a point.
Message 4 of 8
v-silvestre
Well, considering the dynamic function of the pressure part profile labels aren't working as intended, we're limited to options we have.  Another suggestion is if pressure network is pipe run based, you could try to extract a feature from your pipe run alignment, sample that in your sections, create a label style tied to the feature.
Message 5 of 8
Jeff_M
Tom, while the labelling tool only labels one section at a time, I have no problem adding a label to the same pipe in multiple sections...one at a time.
Jeff_M, also a frequent Swamper
Message 6 of 8
Thomas-Glidewell
Strange.. What version are you using?
Message 7 of 8
Jeff_M
Also using C3D 2023, Update 3
Message 8 of 8
Thomas-Glidewell
Jeff
And your labeling pressure pipes?
