Pressure Pipe Labels in multiple section views
Thomas-Glidewell
Thomas-Glidewell
I have an alignment with sample lines that are sampling a couple pressure networks. Sample set at 50' increments. In the section views it is showing the pipes correctly. But the issue is if a multiple section views are showing the same pipe at different locations along the alignment the pipe can only be labeled in one of the section views.
C3D 2023 all updates and such applied.
Thomas G
Replies (7)
v-silvestre
Instead of using a Pressure Part Profile label, you could use a Profile View Label.  Granted it's not ideal and a little more work, you should be able to the annotation you want.
Thomas-Glidewell
Agreed but that as you know takes away from the dynamic labels which change as design changes. Using profile view labels would definitely lead to incorrect data in the plans since they are static to a point.
v-silvestre
Well, considering the dynamic function of the pressure part profile labels aren't working as intended, we're limited to options we have.  Another suggestion is if pressure network is pipe run based, you could try to extract a feature from your pipe run alignment, sample that in your sections, create a label style tied to the feature.
Jeff_M
Tom, while the labelling tool only labels one section at a time, I have no problem adding a label to the same pipe in multiple sections...one at a time.
Thomas-Glidewell
Strange.. What version are you using?
Jeff_M
Also using C3D 2023, Update 3
Thomas-Glidewell
Jeff
And your labeling pressure pipes?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
