Pressure Network Fittings and Valves Plot While On No Plot Style
hestingjj
hestingjj
Using C3D 2019. I have a pressure network representing a non-potable water line data referenced into a drawing that contains another pressure network representing a potable water line.
The non-potable water line is data referenced in solely to draw the crossing pipes in profile. The non-potable line was put on a default layer when data referenced in and the style for the pipes, fittings, and appurtenances were set to a style that will not plot in plan and plot in profile.
When I do a plot of the site in plan, the non-potable water lines do not plot as expected, but for some reason the fittings and appurtenances are displaying. It seems like they are somehow overriding the non-plot layer that the style sets them to (See attached screenshots detailing the style properties and plot results).
Has anyone else experienced issues with this? Other than the fittings and appurtenances plotting, the style works great as the pipes do not plot, and the crossing pipes display in the potable water line profiles as they should.
MODEL PLAN VIEWMODEL PLAN VIEWPLOT OF PLAN VIEWPLOT OF PLAN VIEWNO PLOT IN PLAN FITTING STYLE PLAN SETTINGSNO PLOT IN PLAN FITTING STYLE PLAN SETTINGSNO PLOT IN PLAN FITTING  STYLE PROFILE DISPLAY SETTINGSNO PLOT IN PLAN FITTING STYLE PROFILE DISPLAY SETTINGS
Neil.Aryan
@hestingjj,
Select all the fittings and valves i plan view and send them to C-CROSSING_NPLT layer and try it will work.
i just tried with my drawings and its working if not works for you feel free to explain the same or share the file so that can have a look.
Also make sure that there is no any double fittings added with different style and layers and also there is no any CAD block left in the position.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Project Manager | Civil | ACE Inc.
Certified Civil 3d Professional | YouTube | My-Blog
lynn_zhang
Hello @hestingjj ,
Just checking to see if your problem has been solved. Have you tried the suggestions from @Neil.Aryan and did they work? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
