Civil 3D Forum
Pressure network components not flipping in Civil 3d 2023
2 REPLIES 2
dparsleyXDGXX
260 Views, 2 Replies
In C3D 2023 some/most of the pressure network parts are not able to be flipped, the old flip arrow option does not show up. I've been putting them somewhere off the network then rotating them. Wondering if there was another way to flip the parts. Thanks!
Labels (1)
2 REPLIES 2
Joao-Rafael
in reply to: dparsleyXDGXX
Hi @dparsleyXDGXX
All grips present in pressure network fittings remain active in C3D 2023. See Photo
remembering that you must use SHIFT to select the part without selecting the alignment, in the new versions of C3D.
and that not all parts have this option configured, and this function must be activated in the Catalog.
I recommend reading this article for further questions.
Autodesk Civil 3D Help | Fitting Grips in Part-Based Pressure Network Plan and Model Views | Autodes...
Good luck !
At.t
João Rafael A. Dias
[pt] Esse post foi de ajuda para você? Mostre seu Apoio dando uma curtida! Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução '
[en] Did this post help you? Show your support by liking it! Did your question receive an answer that solved your doubts? Then click on the "Accept Solution" button.
[es] ¿Te ayudó esta publicación? Demuestra tu apoyo dándole un me gust. ¿Tu pregunta recibió una respuesta que resolvió tus dudas? Entonces haz clic en el botón "Aceptar solución"
Siga-me // Folow me LinkedIN
jroman
in reply to: Joao-Rafael
I have the same problem, but with the bends.  There is no any way to flip the bend. I am using civil 3d 2023.
Rail Community
