Pressure network chamber
FrankSiosiuaNelisi
FrankSiosiuaNelisi
How would you create a pressure network chamber? As I would like the pressure pipes to enter a chamber, which the chamber is referenced to the surface.
Hi franksiosiuanelisi,
Currently there are no cambers are available in pressure network default catalogs in civil 3d (not sure about 2017). Normally when i do modeling i always add pipe networks to add any chambers in to pressure network. you can also use the same way or still if you would like to add chamber in pressure network, You have to create your own chamber, and export to as a content file and and import through content catalog editor and create.
I have done for other user defined fittings it works for me.
i can help you on this if in case of need
Skype: Sandy.spartha
Cheers,
Timothy_Sean_Hulbert
Greetings,
Thank you for your recent forum post.  My name is Sean and I am more than happy to help you with this issue. I see from the thread that other members of the community have been working with you on this issue regarding Pressure Network Chambers. You could use the Content Catalog Editor to create the custom part you need for this scenario.
I have subscribed to the thread though and will continue to monitor it should you need additional assistance. If you would like to communicate directly, you may do so at any time by sending me a private message in the forum.
Timothy "Sean" Hulbert, PE
Product Support Specialist
Link Name | Link Name | Link Name | Link Name
