Pressure Network Appurtenance Parameters
I'm using Pressure Network and I have created a water system. I would like to know how can I make the Appurtenance gate valve showing at the right depth and have a vertical pipe going until the surface? All my gate valve are showing underground at the right invert. I'm been ask to have the rim valve at the surface elevation.
Cadguru42
Civil 3D's pressure network system does not have a way to have parametric fittings nor appurtenances. This means that you won't be able to use a pressure network appurtenance to display correctly. I have been manually drawing a rectangle to represent the valve box on profile views. In your case, you can use a profile view label or a surface label at the valve's location to show the "RIM" value.
C3D 2024-2026
Windows 11
32GB RAM
