Poor 3D performance
Since I started using Civil3D 2024, I've had performance issues that I cannot explain.
First of all, this is the version I'm running (I believe it's the latest)
My computer is a laptop which runs the latest upgrade of Windows 10, and I'm quite sure the hardware is not an issue:
CPU: Core i7-13700H
DGPU: NVIDIA GeForce RTX 4060, 8gb VRAM, 120W power limit
And the disk is an SSD.
My issue is poor 3D performance. When I try to orbit a not too large model (e.g. a contours representation or a small TIN), it is extremelly laggy and really uncomfortable to use. Sometimes, turning off hardware acceleration makes it run better, but I don't think that's the solution (one of the reasons I bought this computer was to have good performance in CAD and CAE software, and having to disable hardware acceleration to achieve this is definitely disappointing), and sometimes I simply am required to use acceleration (e.g. LiDAR pointcloud).
I of course use my computer while plugged, and with all the power settings set to max performance. The version of DirectX I use is 12, but I've already tried the command to use DX11 and no luck.
I know that GeForce cards are not as optimized for CAD and other similar applications as workstation cards, but this one should definitely at least work well for this little load, so I assume it's some kind of configuration issue. I'm using the latest Nvidia Studio Drivers, too, so that's not the cause either.
Any suggestion would be appreciated.
Thanks in advance,
Lucy
