Message 1 of 17
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
Here is the situation, i received a point cloud containing 12milions points. This number makes impossible to work with a surface created from that many points. To simplify that, im planning to use the alignments ticks (because they are perpendicular to my algnment), spaced 20meters from each other, as transversal lines, and from those ticks i would explode them and turn them into lines. Finally i would use the Polyline Vertices command to create gogo points from those lines, but since the existing command doesnt allow me to apply into multiple objects i got stuck.
Now i'm looking for a lisp that has the same objective as the Polyline Vertices but i could use in multiple objects
