Polyline that crosses viewport plot with different thickness
henrikCNQJX
Message 1 of 15
henrikCNQJX
Hi, I'm having an issue with plotting where some polylines will have a different thickness after plotting when they cross a viewport.
I've attached two pictures. In one of them I have broken the polylines a small distance before the viewport border and in the other one the polylines are continuous throughout. For some reason the error in thickness stops a small distance after the second viewport has begun even though I only broke the lines on the left side of the border.
This is running Civil 3D 2026.1 Update. Plotted with AutoCAD DWG to PDF plotter.
Replies (14)
Message 2 of 15
ianjchap
Hi @henrikCNQJX
Do you have a difference in the VP colour (and therefore the plot) on that layer through either of the viewports?
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 3 of 15
cwitzel5NL5H
I have been having a similar issue with contours in 2026 also using DWG to PDF.  At the edge of the viewport they are thicker than in the center.  I keep meaning to try a different PDF printer, but keep running out of time and printing from 2025.
I have some time this morning and may try.  I will report back here.
Conan Witzel
Herrera Inc
Message 4 of 15
henrikCNQJX
No difference. And even so the error is visible in both viewports.
Message 5 of 15
ianjchap
Are you able to share the file?
Ian Chapman
Message 6 of 15
henrikCNQJX
I've had this similar issue in previous version (I think 2016 or 2017) and didn't think it would be dependent on the version of Civil 3D. But I just tried plotting in 2025 and had no issue what so ever so that seems to vary then.
Attached a pic of a plot with 2025 and that looks exactly as it should.
Message 7 of 15
henrikCNQJX
Sure, I've attached a ZIP with the eTransmit of a sample of the file. It does produce the same error for me. A PDF is also attached for comparison.
Message 8 of 15
ianjchap
Thanks, Can you share your CTB also?
Ian Chapman
Message 9 of 15
henrikCNQJX
Should be included in the eTransmit ZIP no? In the PlotCfgs folder.
Message 10 of 15
ianjchap
Same for me, plots fine using 2024. Do you have any previous version to revert to temprarily that may work?
Ian Chapman
Message 11 of 15
henrikCNQJX
Yeah I've got 24 and 25 installed so that's always an option. Would be nice to get to the bottom of the issue though 🙂
Message 12 of 15
ianjchap
Agreed. If it works with another version at least you'll know it's more likely to be an issue with 2026.1.
Ian Chapman
Message 13 of 15
cwitzel5NL5H
I tried a number of PDF drivers and nothing worked well except for Bluebeam, which is it's own annoyance.  Affecting both STBs and CTBs.
This is the same drawing printed in 2025 and 2026.  A single surface nothing different about them other than the version.
2025:
 2026:
We are hopefully starting a ticket through our reseller.
Conan Witzel
Herrera Inc
Message 14 of 15
mgocobachi
Observer
Observer
I have this issue too, I just discover that for me this only happens when I have a clipped viewport, if you don't need your viewport to be clipped, I suggest deleting it with VPCLIP command
Message 15 of 15
cwitzel5NL5H
A temporary fix has been posted here:
Plotting or publishing to PDF results in uneven lineweights for some drawings in AutoCAD 2026 produc...
This worked for us.
Conan Witzel
Herrera Inc
