Points Import
yara_khoury
Points Import
yara_khoury
Hi, i have the following point format:
1-95.5574329.9386120
that I would like to import into the right place.
Under drawing settings, I have chosen: TX83-SC.
Under the import points, i have edited as below. The points are not getting to the right place. What am i doing wrong?
Replies (7)
Pointdump
Hi Yara,
Probably because of the "Raw Description" header.
Can you post a snippet of your point file?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
yara_khoury
Hi Dave, the points are getting into the drawing, but not in the right place.
tcorey
It looks like you are trying to import points from Latitude/Longitude and have them placed in TX state plane?
You need to create a Point File Format that specifies those column data. As part of the Point File Format, you need to tell Civil 3D what coordinate system the point file is coming from. Something like LL84.
Be sure to click the box for Coordinate zone transform.
When you import the file, be sure to select this Point file format and click the box to Do coordinate transformation if possible.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
yara_khoury
 i believe it worked thank you. I check the points long and lat with google earth, and they are the same.
However, now i am trying to import the KMl file into C3d using map import. The points came from the KML, but the objects in the kml files are getting imported much smaller and completely different place. I used the same LL84 when i used the map import function. Why it is not working ?
brian.strandberg
Do you have the proper coordinate zone set in your drawing?
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
yara_khoury
I thought i should set it to LL84, that's what i did.
Pointdump
Yara,
#Pt,Longitude,Latitude,Elevation
1,-95.5574,29.93861,811.5543
2,-95.5572,29.93861,914.6982
Those points are definitely in Texas South Central. TX83-SC is a Metric Coordinate System. (Are your elevations in meters or feet?)
You only need to check the "Coordinate zone transform" box if your points are in a different Datum than NAD83. If they are WGS84 then do as Tim says. If the Longs and Lats are the same NAD83 that TX83-SC uses, then nothing need be done there.
Dave
Dave Stoll
Las Vegas, Nevada
