Points created from a Surface
bnagel
bnagel
I created some pionts using Random Points routine which used a proposed surface. The surface was modified slightly. How do I update the points to coincide with the revised surface without having to manually edit them?
TIA,
Bob
bnagel
Disregard, I found the solution
tcorey
Well...would you like to share?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
bnagel
In my dwg file, I went to Modify tab. Then click on points, then Elevations from Surface. Follow the prompts.
Thank you,
Bobby Nagel
Survey Manager
ConTech, Inc.
114 South Elm Place
Broken Arrow, OK 74012
Cell: 918-841-0827
Fax: 918-259-0857
bnagel@contechinc.net
AllenJessup
So you're modifying them one at a time. I bought Sincpac to dynamically link the points to the proposed Surface. Saves a lot of time when there are last minute changes to the grading and I don't have to edit all the stakeout points.
Allen Jessup
CAD Manager - Designer
bnagel
No, I created a point group and that is an option.
AllenJessup
Thanks. That's good to know.
Allen Jessup
