Civil 3D Forum
Point style problem in civil 3D 2015
4 REPLIES 4
dilsmails1
5380 Views, 4 Replies
Hai I have a problem in point style using (_ddptype/ddptype) commands in civil 3D 2015.it says unknown command. I already run a “reset setting to default” but the problem is not solved. Actually what happens Autodesk rename that command or not? I know we can use pdmode, pdsizs etc..any budy can help. Where can I found the same command in pull-down menu or toolbars. I want to see the point style wizard to make modification easily.
Dileep
4 REPLIES 4
Jeff_M
in reply to: dilsmails1
Use the command PTYPE.
Jeff_M, also a frequent Swamper
dilsmails1
in reply to: Jeff_M
Thanks sir, pblm solved
Dileep
Lisa_Pohlmeyer
dilsmails1
in reply to: Lisa_Pohlmeyer
thanks
Dileep
Rail Community
