Point style marker
Point style marker
Message 1 of 13
Point style marker
Hello , i want to change Autocad point for Marker , to cross style marker . I tried to change it to PDMODE . Default is simple point , i try to change it to cross style but wont work. Can someone help?
Replies (12)
Message 2 of 13
user181
Maybe it is a civil 3D cogo point and not an autocad point?  If so select the point and look at the properties palette, if it's a cogo point change the Style in the Information section. The Basic style that comes with civil 3D is an x. You can also edit and create your own style.
Message 3 of 13
rkmcswain
Did you REGEN after making the change to PDMODE?
Okay, in 2018, regardless of the setting of REGENAUTO, changing PDMODE causes a REGEN. So nevermind....
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 13
REGEN??
Message 5 of 13
I want to use autocad point for marker , with x mark. Is there anything i can do? I dont know what REGEN is sry. Im new to civil 3D.
Message 6 of 13
Todd_Rogers
If you want to change the AutoCAD point style, it's PDTYPE, not PDMODE.
Todd Rogers
Civil Administration
Message 7 of 13
rkmcswain
Message 8 of 13
cwr-pae
 Your being new to the program, I recommend you find some training classes or training manuals to learn C3D basics. The learning curve is a huge headache otherwise. This forum can't teach you from scratch how to use the program.
What you want is possible. A quick run down of what to do for the point you are wanting. You will need the manual or classes to understand the some of the terms used or the intermediate steps required that I don't list.
Under the points menu you can create COGO points directly or convert them from ACAD points. Then you need to find, create or edit some point styles to display the points and label them.
Message 9 of 13
Todd_Rogers
HAR HAR, funny Randy...lol. If he is anything like me, I need to SEE it, not guess at it...
Todd Rogers
Message 10 of 13
Todd_Rogers
And YOU get the solution @rkmcswain Smiley Frustrated
Todd Rogers
Message 11 of 13
Thank you guys for responding.Thank you Rkmcswain for your solution.
Message 12 of 13
rkmcswain
I heard an Expert Elite qualification was to have those memorized....?
Message 13 of 13
Todd_Rogers
I heard another qualification was to not rag on the Autodesk employees...lol Smiley Very Happy
Todd Rogers
