- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I've got a questions about point styles. I've created point styles that looks like its in drag state in a default state. I just made 4 blocks that have leaders in the Top Right, Top Left, ect... and made Point Label Styles to plop the desired point attribute at the end of the leaders. This has became very useful as myself and others in my company deal with pipe lines quite a bit and tones of points along the such pipe lines that need to be dragged off the pipe so they're esthetically pleasing. This poses a problem though. If the default point style "drag state" is not in the desired location and you DO put it in a drag state, the leader on the point style I created still exists.
Is there a way to change the point style to a designated point style when you drag the attribute and put the points label style in a drag state?
I haven't found a way to do this and I'm thinkin theres no way to change the point style depending on whether the point label style is in a default location state or in a drag state.
Any ideas?
