Civil 3D Forum
Point Label Style
2 REPLIES 2
278 Views, 2 Replies
Point Label Style
Is there a way to use a refernce text or an expression to show the cut /fill grade on a surveyed point that has an existing ground elevation assigned to it already.Ie refernce to another surface in the point label style I am using C3D 2014
2 REPLIES 2
If you create a surface with the surveyed points, you can create a volume surface and add a spot elevation label based on the volume surface on top of the point.
Thanks that is how I handled it but I was wondering if reference text or an expression could be used the other alternative was to use sinpac-display points-refernce the design surface-print these to file move the cut/fill to the description column and the reimport the points with the cut/fill in the point number as the description.
Rail Community
