Hello, everyone.
I have two projects. In one of them, the point lables are appearing with double line (this is the one I want). In the other, they appear with single line.
I don't know what setting is making it happen.
How can I change the one with single line to double?
The orange one is wrong and the red one is right.
Hello, everyone.
Solved by Pointdump. Go to Solution.
Hi @matheus_spo,
Welcome to the Autodesk Forums.
Can you post your two drawings?
Dave
Dave Stoll
Las Vegas, Nevada
Hi @matheus_spo,
Dave
Dave Stoll
Las Vegas, Nevada
Hi! Thanks for the quick reply.
"Pontal" is the one with double lines. "Matinhos" is one of the drawings that I need to apply this standard.
@matheus_spo,
Thanks for posting your drawings.
In PontalPressao_Set22 drawing your Standard Text Style uses romand.shx Font.
In MatinhosPressao_Set22 drawing your Standard Text Style uses txt.shx Font. Changing to romand.shx fixes things up.
Dave
Dave Stoll
Las Vegas, Nevada
@matheus_spo,
Dave
Dave Stoll
Las Vegas, Nevada
Your label style is using the Standard text style. In the one showing double lines, if you type in STYLE, then select Standard, you will see that the font is romand. Romand is a double line font. Change it Simplex. See attached...
Here you go. See attached...
@Pointdump and @ToddRogers-WPM thank you for the right solution!
