How can I create a point style so that when I change the layer of the point, the colors of all three text change to the color of the layer the points were placed on? I know that I can edit the text of the point and, one at a time, change color by layer, but that is only for one pooint. I want a point style that will display the colors of the text the same as the layer it was placed on. In my point style, I changed the all the colors to by layer but that didn't work.
Solved by Jeff_M. Go to Solution.
Are you referring to Point Label Styles and you wish to show the Point Number, Point Description & Point Elevation
all as different colors?
If yes then create separate component's within the Point Label Style and assign them each their own color within the label style.
As far as I know Civil 3d doesn't have a means of placing the various point components on individual layers at this time.
As an example, we have multiple point label styles that show Pt #, El, Desc and others which only show one of these
components per style.
A,
An easy way to change properties of one or several points is in the Edit Points Panorama:
Dave
Dave Stoll
Las Vegas, Nevada
Your suggestion was good as I didn't have the General tab set to 0. It still didn't work until I set the two layers in the basic point to 0. Then it started to work like I wanted. Thanks for your input.
