Point Group Order
Point Group Order
jroot
Advisor Advisor
Message 1 of 11
Point Group Order
jroot
Is there a way to automate the elevation of the "_All Points" point group from either the command line, LISP, or Action Recorder?  I want to quickly move it to the top without going through the dialog box.
Replies (10)
Message 2 of 11
Kevin.Spear
Not that i am aware of. But there are survey add-ons to c3d that provide a saved sort order of point groups that you could then recall, like a saved view. One add-on is the Sinc-pac from Quux software.
Kevin
Kevin Spear, PE
Message 3 of 11
Jeff_M
Although I am partial to the tool @Kevin.Spear mentioned in the Sincpac, here is a small .NET program you can load and run the command MoveAllPointsToTop . Before unzipping the file, be sure to Unblock it by going to the file's properties and click the Unblock button. Then save the dll wherever you wish. Use NETLOAD to load the dll into C3D. This dll should work in most versions of C3D, tested in 2016 & 2018. You could even create a small lisp to load and run the command.
For anyone interested, the entire c# code for this tool is:
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.ApplicationServices;
namespace PointGroupTools
    public class Class1
        [CommandMethod("MoveAllPointsToTop")]
        public void moveallpointstotop()
            var civdoc = CivilApplication.ActiveDocument;
            var ptgrps = civdoc.PointGroups;
            var allpts = ptgrps["_All Points"];
            var neworder = new ObjectIdCollection();
            neworder.Add(allpts);
            foreach(ObjectId id in ptgrps.DrawOrder)
                if (!neworder.Contains(id))
                    neworder.Add(id);
            ptgrps.DrawOrder = neworder;
Message 4 of 11
jefflambert9091
How about taking it back down? 🙂
Jeff
Civil 3D 2024
Message 5 of 11
Jeff_M
And here is a new dll which includes two commands: MoveAllPointsToTop and MoveAllPointsToBottom
The code for the second command is:
        [CommandMethod("MoveAllPointsToBottom")]
        public void moveallpointstoBottom()
            foreach (ObjectId id in ptgrps.DrawOrder)
                if (id != allpts)
                    neworder.Add(id);
Message 6 of 11
jefflambert9091
Thanks!
Jeff
Civil 3D 2024
Message 7 of 11
jroot
This has been a huge help @Jeff_M  and I need to ask another huge favor.
Could you compile another dll for me that moves a group called "No_Display" to the top? (to go along with MoveAllPointsToTop)
I started fumbling my way through Visual Studio but kept getting glassy-eyed.
Message 8 of 11
Jeff_M
@jroot here ya go.
Message 9 of 11
jroot
Beautiful!  Thank you for your time and talent @Jeff_M !
Message 10 of 11
Hi @Jeff_M,
I've been getting into the lisp routines to simplify my processes but now trying to do something similar for ordering the point group. This C# and dll is a bit over my head, but the code works great for "_All Points". Would you be able to find the time to tweak the code for my specific point groups.  I've given it a shot but clearly missing one specific line in the attached.
Message 11 of 11
Jeff_M
@Anonymous sorry I missed seeing your message until now. Your code was close, just need that highlighted line to be like so:
if (targetpg != ptgrps.DrawOrder[0]); then <<<<<<<<<<<<<<<<<<<<<<<
