Announcements
Point exclusion from point group
nemethattila
nemethattila
Hello!
I would like to exclude points from a point group, above high 93.4, but it's doesn't work with not integer numbers.
What could be the solution?
Thank you!
(Sorry for my english 🙂 )
jroot
You don't say for sure but I assume you mean by elevation?  I just tried one here and I was able to exclude points by elevation to the tenth decimal.  Or are trying to exclude points by point numbers?
AllenJessup
Let us know what version of Civil 3D you're using. If you could post a drawing with a sample of your points and point groups. That would also be helpful.
Allen Jessup
CAD Manager - Designer
nemethattila
Thank you the replies. Civil 3d 2020 software. I could do it. In the Windows control panel must change Hungarian language to English (United States of America)
CemilYuksel
Hello Nemethattila,
As I Understand you want to exclude some of points from Point group. For this you need to determine elevation condition under the Exclude Tab. Please See Capture1. After this step If you want to see Point and Label Style You should check Point Elevation Under the Overrides tab. Please see Capture 2. I hope this solution works for you.
