Changing alignment starting station
Hello everyone,
I've encountered a problem, when I draw the alignment, my starting point is at the top-right corner (+0+000m) and form a closed loop. I want to make the starting point at the bottom-left corner, and have changed it as (+0+000m). However, some of the stations along the alignment appears to have negative value (i.e. -0+423m).
How can I at the same time make the station at the bottom-left corner as (+0+000m) and appears no negative value stations along the alignment?
Thank you.
Todd_Rogers
Change the Reference Point under your Station Control in Alignment Properties.
Todd Rogers
Civil Administration
Thanks for your reply. I've changed the reference point, but the station information starts with negative number. When I add the alignment label, some negative number will appear. So how can I deal with such issue?
Todd_Rogers
Can you post the drawing?
Todd Rogers
I got the label like this. Bottom-left corner with 0 and increase clockwise, but after reaching the original starting point, the number start to decrease.
cwr-pae
The problem is based on the way alignments exist as single entities. Alignments are actually Cartesian in nature, everything is based on a straight line and offsets from that line. When you move the 0+00 point, the line is still there, with the same total length and anything before the new 0+00 point will be considered negative. To 'fix' the alignment you have to remove the part before station 0+00 and recreate it starting at the far end (highest station remaining) and drawing towards 0+00 from there.  You could probably try playing games with station equations to make the negative stations read as higher station, and the station above 0+00 would need an equation to read lower. but I think that would be asking for confusion.
If I had to do that I would explode the alignment, create a small gap before where I wanted 0+00 and recreate the alignment, closing the gap after creation.
