Point error in survey database
richardKTHG4
richardKTHG4
Hi All,
I am bringing in a field book from a leica CS10 and only have 2 made code points STN for Station and GL for a ground level. The STN should come in with a triangle symbol and the GL with a cross. When I import the points I get both on each point.
Any idea what I may have  messed up please?
Regards
Rich
tcorey
Can you post the .fbk file?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
richardKTHG4
Hi Tim,
Here is the field book file and a screen shot of what happens.
Regards
Rich
rl_jackson
Nothing attached
Rick Jackson
Survey CAD Technician VI
richardKTHG4
It will not let me upload it for some reason?
richardKTHG4
I have had to change the file extension from fbk to txt to allow it to upload.
Regards
Rich
rl_jackson
First of all since that was done with GPS you should download a PNEZD** file file from your data collector. I can bet that somewhere within the fbk file you have there is a point name vs number. That's why it won't import and errors out.
Rick Jackson
