Message 1 of 10
- Mute
- Permalink
- Report
I tried to insert points using "create points - alignments - from file" using a text file that was hand generated. The file had a space after the elevation, right before the comma that precedes the description. I used option 5 (station, offset, elevation, description). All the data came in except the elevations of the few points that had a space after the elevation. Why does this happened in a comma delimited file? Is there a fix for this?
