Point Cloud to Contour Plot
dmm5
Message 1 of 8
dmm5
Is it possible using Civil 3D to import a .csv point cloud, Lat, Long, and Elevation in meters (that I collected from Google Earth Pro), and convert it to a contour plot with lines at 0.5 meters?  If so, may I also convert metric elevations to imperial (feet) and Lat, Long, coordinates to Northing and Easting format?  So, I want to go from my .csv file to something resembling a parcel map with contour lines 2 feet apart.  Many thanks.
Replies (7)
Message 2 of 8
Pointdump
Hi @dmm5,
Let's see what you've got. Can you post your CSV?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 8
dmm5
Sure thing...
Thanks.
Message 4 of 8
Pointdump
@dmm5,
Thanks for posting your CSV file.
There is more than one way to do this. Here's one way:
1. In Excel multiply the Elevation Column by 3.28084 to convert it to feet.
2. In Civil 3D use an Imperial Template and assign CA83-IVF Coordinate System.
3. Create a custom Point File Format to recognize the Lat,Long,Ft CSV file.
4. Create a Surface and add the CSV to the Surface Definition.
Drawing attached.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 8
dmm5
Dave,
Outstanding!  Regarding the conversion of meters to feet in excel - don't know why I didn't think of that.  Regarding the rest, I'll be poring through this for a while but it looks like exactly what I want.  It looks like you did it for me!  Thanks, I'll post a progress report...
Dave (my name as well)
Message 6 of 8
dmm5
Dave,
One final question.  Is there a way to improve the quality of the contour fit?  There are sharp angles in the contour lines that are fit-artifacts, and not the result of the actual topology.  Furthermore, if I do this more than once I get different artifacts.  I was hoping for something smoother.  There is, after all, plenty of data.
Many thanks,
Dave
Message 7 of 8
Pointdump
Hi Dave,
There's a distinction to be made between smoothing the surface and smoothing the contours. Read >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 8
dmm5
Cool enough, Thanks again.
