Thanks everyone for your responses.
I was having mixed results with my 130acre drone photogrammetric data set over the weekend. My AOI is attached for those interested). Lots of elevation relief. Used a Phantom 4 Pro and Trimble R8-3 rtk-gps to set GCPs.
After processing the 1146 images in pix4D, I did the default point classification in Pix4D. Then I imported 5 .las files outputted from Pix4D into ReCAP 2019 to process for eventual inclusion into C3D19.
I first tried to use the DotSoft C3D Tools Mass points on the raw .las files mentioned above to build a quick surface from the classified ground shots, but I got an error (maybe my sets were too big).
So then I used mapcreatepcsurface command after inserting an overall combined ReCAP .rcs point cloud into the drawing. This command built a solid GeoTiff from the classified ground shots. However, the DEM surface you get from the GeoTIff in C3D is enormous and you can’t simplify the surface via C3D surface edit because it is a DEM grid surface. You can’t even export to LandXML to bring it back into C3D to simplify either. However, once this surface was in C3D, this surface closely matched the formal aerial survey we flew early in the year. Flat areas and side slopes looked with 3-6” or better. But the dwg file size is almost unusable.
I also tried the Infraworks engine to process the overall ReCAP file and exported out an “Optimum” .IMX of the resulting terrain surface to C3D. I then compared the processed terrain surface vs. the Point Cloud in Infraworks and I could see reasonable attempts to exclude man made structures. I was very happy in Infraworks until I checked against the formal surveyed surface in C3D. Did the same checks against the formal survey surface, and noted more error on side slopes than I would like. The .imx data was parsed and easier to work with in Civil 3D though, so that is a plus, but I don't trust the output despite it looks pretty in Infraworks.
It looks like I need to do research on 3rd party platforms (off the Autodesk ranch) to both auto-classify point clouds from Drone imagery and get something that has processing options on the back end to allow the resulting surface to be down-sampled or parsed, but accurate enough to be usable for design and earthworks.
Thanks again for everyone's input.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
![](https://i.ibb.co/wrnrQ2m/autodesk-expert-elite-logo-1line-rgb-black.png)
