Ok we have a cannon iPF755 plotter. It has a 36" wide carriage.
I need to plot a city map that is 48" wide by 54" so that it will fit in the frame they have for it.
My intent was to set up the plot as a PDF and send it to a local print shop.
My problem is the drivers will not let me set up the sheet with a 48" width only 36".
Any ideas or tricks ?
Would it work to download Cannon drivers for a model that is 48", and set up the pdf file that way.
C3d 2018 in use
Dave Z.
Solved by JessicaPalmer. Go to Solution.
Hi @Anonymous , If you PLOT and use the DWG To PDF.pc3 printer and select properties and go to custom paper sizes you can add any size paper you want. Then just use that .pc3 and paper size to plot to PDF.
When using a .pdf plot driver you should be able to add a custom sheet of any size.
