Dear friends, this spawns from my last post "has anyone used transparency before".
I do not know if using transparency has caused this or not but; now I seem to have problems controlling my hatch dark/lightness.
I am running in to differences between hatch darkness depending on whether I plot straight from civil3d, or plot from a PDF file.
It seems as if my hatch pattern is printing out darker from civil3d than it plots from a PDF file.
I will post my drawing, perhaps someone could explain to me what is happening?
Should it not plot the same from civil3d as it does from a pdf file???
Solved by rl_jackson. Go to Solution.
Your ctb/ stb file would be helpful to look at.
Using our pen file it looks fine either way. color 252 is a natural halftone. You have mentioned transparency but your hatches and layer are set to 0 = no transparency?
the natural halftone setting on our system is this:
is yours similar?
Joe Bouza
No worries. post your ctb file. I give a look on Monday
Joe Bouza
you are correct about scale and all. (it is our livelihood so I guess it makes sense that is a lifetime of learning.)
If you are using ctb plotting then the plotted line weights and shading are dependent on the screen color. The screen color is mapped to the plotter by way of the ctb file. if you look at my earlier post you see the various setting for each screen color. the screen color and plotted weights assume you are plotting at some scale... so if you use screen color 1 (red) to plot a bold line based on the idea of a 20 or 30 scale drawing - that screen color may not work for 60 or 100 scale; you get black smudges. This is where your cad standards come into play.... plans and screen colors have to adapt to the scale of the ultimate plotted drawing; hence layer states and what not.
there is a scale line weight check box on the plot dialog. I use this when plotting full size to have size to compensate for the pen weights at full size, I also have a second ctb for smaller plots that redefine the pen weights by half for the congested larger scale plans
Joe Bouza
Looking at your set up(even though I have been plotting surveys successfully for a year) shows me that: A) mine is set up differently. B) I probably do not have a good grasp on how to plot correctly but have been getting away with it. I am not familiar with cad standards so I may have the whole thing set up incorrectly. I actually do not understand what all of the settings mean in the CTB plot file.
For example at the top-right I have all of my chosen colors set to black, otherwise my drawing prints in colors so I assumed that this is how you print black even though I am using colors to control light/darkness. I see that you have pen numbers and virtual pen numbers assigned,I do not because I do not understand what that means or how it works.
Basically, what I have done is randomly chosen colors for every line type, text font, and hatch pattern that I may want to lighten/darken.....I control most, if not all of my line weights just using layer colors and in that particular layer I assign it a line weight in the layer itself; such as my 3 different fence types I assigned them all the color of 20(I think) in layers. I then assigned them a line weight of .13mm. My boundary line is assigned as blue in my layers with a width of 8mm(I think). If these lines plot too thick or too light based on the particular drawing or scale I am using, I simply go to the layer and change the line weight. Very simple and uncomplicated.
However, I added some complication when I decided to start using a CTB file to control the light/darkness of certain text fonts and hatch patterns. Actually it never seemed all that complicated until recently. For example I have a few text fonts that I have lightened up using the CTB file which works fine other than it seems that the light/darkness of these text fonts seem to vary depending on the scale I am drawing in. Also I have about 6 different hatch settings that I control the light/darkness in the CTB file which normally works fine.
Then I further complicated things by using transparency on one stubborn text font that did not seem to respond to the CTB file. I can not remember the name of the font but it is for my" BLOCK".....as in lot 5 BLOCK 12. I will try to find a drawing to send that has this font in it. So the transparency does Lighten up that text font but also seems to affect my hatch patterns which I never assigned any transparency to.
I hope I am wording this in an understandable way because it really seems that this can become very complex. And complexity is what I am trying to get away from. I either want to learn the correct way to use all of these factors, or either start eliminating some of them to make my life easier. For example, I do not necessarily HAVE to use transparency but it would be nice to be able to have it in my arsenal. Also I could do away with my CTB file and just let everything print "as is" but that would be taking away some flexibility in the program. Or I could have one hatch pattern with only one color and change the line weight in the CTB file every time I plot if it does not look right. This is enough to make my head spin around.
How @Joe-Bouza shows things being set up is just one of many methods. I don't set any pen widths in my CTB file, selecting instead to set all weights to by object. This allows me to set the weight in the layer settings without ever thinking about a color printing with a certain weight. While at the same time allowing my the option of making changes to the object in the properties to change it's weight.
Rick Jackson
Survey CAD Technician VI
very cool @rl_jackson, I always thought that was for stb method.
Joe Bouza
Rick Jackson
Thanks YODA, I have mine set up like yours but did not know what I was doing. But it worked so thanks for insight. Two questions
1) under line end style what is the difference between butt, and square?
2) under line join style you have yours chosen as round. Can you tell me why you have this selected instead of"use object join style?
Rick Jackson
@rl_jackson Rick, I'm liking the idea, but from a cad standard point of view, is there a way to prevent a user from changing the object weight in the layer dialog? I'm wondering if the door to inconsistency can be left open or not? .... I guess in the screen color method there is nothing stopping a user from making a pline with width.
I'm trying to come to grips with the benefit of use object weight vs pen weight?
Joe Bouza
Rick Jackson
Yes Multi user.
the pen assignment is nearly identical to using the object weight assignment. The virtual pen assignment is merely to assign for black and white vs color prints. virtual pen 7 is always black and virtual pen # tell acad to plot that color; 256 colors 256 pens
Joe Bouza
