Plotting Cross Sections Issues
chad.gillespie
chad.gillespie
I am having issues plotting section views. The exsiting ground is not showing up as an option and i can't seem to get the settings correct. I have attached a PDF of an example of the end outcome I would like it to look similar too and the CAD drawing i am working with.
Todd_Rogers
You didn't sample your existing ground. Create the cross sections, click on one, and in the ribbon, choose Sample more sources. Add your existing ground to the right side of dialog box...
Todd Rogers
Civil Administration at Walter P Moore
Todd_Rogers
Your drawing is fixed and attached...
Todd Rogers
chad.gillespie
How to you create the labels similar to the PDF?
Also the settings to have it plot similar to the PDF?
Todd_Rogers
You will need to play around with the label styles and the band style.
Todd Rogers
