Plot Styles
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear sirs, all of a sudden I am forced to get an education on plotting. Hope this rabbit hole is not too painful. Please bear with me and teach me.
I am new to the idea of colors, layers, and plot styles controlling the appearance of your drawing. I will try to carefully word all of this in the hope of getting a full understanding.
I have a client that is extremely picky about every aspect of his drawings, and is able to pick things out that I would not have even noticed. He uses colors to control thickness and darkness of certain objects. I always thought this was controlled in lineweights through layers, and the color did not matter.
He gave me a list of pen styles:
SLOT NUMBER COLOR LAYER LINE WIDTH
# 1 RED .008
#11 PINK .010
#7 White .012
#6 MAG. .014
#3 GREEN .016
#5 BLUE .018
#9 GRAY .020
#4 Cyan .022
#2 Yellow .024
I attempted to create a ctb file using this criteria but did not seem to get any difference in appearance in my drawing. For one thing there are no mm's that match .008, .012, etc. so I used inches and could find close matches but not exact. So my first question is can anyone show me how to set this up correctly?
2) Also I do not know how to plot without my layer colors plotting out, so I have always chosen grayscale which prints out in black and white. The problem is that if I use a ctb file I can no longer use grayscale so: How do I plot my drawing in black and white without the colors of my layers showing up??
3) If, while using this guys ctb file does that mean that every annotation, object or linetype I draw will have to use the same layer and color that he uses in his drawings to match his appearance??
4) Am I correct in saying that ctb is an alternative way to control line weight and annotation darkness other than using lineweights in layer control?? This is a bit confusing to me. I thought once you chose a text style, text height, and lineweight(in layers) all was done.....
In dire straights(please help)
