Plot preview is not showing image transparency on the print preview.
Yes, TRANSPARANCYDISPLAY is on and you can see the actual image transparency.
Yes, the object transparency is bylayer
You can see the transparency change in modelspace, however the transparency does not change in the paperspace viewport (even thought VP transparency is set to not 0.)
The actual pdf made is correct, just the preview is not showing correctly.
This has happened on multiple computers.
I am running Civil 3d 2020.5.3
JL
JL
C3D 2024
Win 11 Pro
