I am trying to create some plan and profile sheets. I have my template set up. I set up my view frames. I am curious though as to why my profile looks so small here? The scale of the profile view style is V: 1" = 20' and H: 1" = 40'. I created this plan and profile using the create sheets creation tool. Thank you
Solved by tcorey. Go to Solution.
Open the template (.dwt) file. Is the expected scale set correctly in the properties of the viewport in question?
Yes. Set the scales in the template and re-create your sheets.
Okay. Thanks. So if I want to create sheets with H: 1" = 100', that's what the model scale from which the sheets are created from should be? Do I need to change the profile view style when I bring it in? I notice that the profile view style changes to current horizontal scale of 1 when I bring it into another layout using the sheet creation tools.
