Pipe profile grip not displaying elevation
Pipe profile grip not displaying elevation all of a sudden. Checked other files and it is the same.
Until now I could select the pipe invert grip to see and edit its elevation value.
Does someone know how to turn this back on?
erdemcelenk
You mean you had some pipe network label on the invert and now you do not have any?
Erdem Çelenk
Civil Engineer,MSc.
Are you talking about editing elevations in the properties?  I don't think I've ever been able to edit pipe elevation properties by selecting the profile. You have to select the plan view.
BrianHailey
Make sure your dynamic input is turned on and that "Enable Pointer Input" and "Enable Dimension Input where possible" are both enabled. To access the dynamic input settings, go into your drafting settings (DS at the command line).
2018-09-11_0805
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
That's it! Thanks guys.
My dynamic input was turned off. Solved as per Brian Hailey's post.
With dynamic input turned on I can select the pipe invert grip in a profile view to see and edit the invert.
Thank you to everyone.
kim
Dynamic Input is on and I still do not have the pipe grips
