When I hover over a Structure or Pipe in a Network the tool tip displays the Name, Style, Layer, Network, and Size.
I was wondering if there was a way to customize what it displays? I would like to change it to display the Rim Elevation and Sump Elevation. Or for a pipe the Start Elevation and End Elevation. Is this possible?
Solved by cyndycyndycyndy. Go to Solution.
This involves executing CUI to customize the user interface. You should make a copy of the C3D.cuix file before proceeding to be safe. The rest should be explained by the image below.
