Pipe Network rules: Potable Water 1.2m below surface doesn't work
mhvam06
mhvam06
Hello everyone,
I am having problems with pipe network rules and potable water.
The objective:
I have proposed elevations from a landscape architect. These elevations will most likely change during the project and I would like to make the potable water as dynamic as possible.
I would like to assign a pipe network rule with a minimum cover of 1,2 m which will update the pipes when I hit "Apply Rules".
I have tried doing it but it ends ups looking like the image below.
Green line: Proposed terrain
Light blue: The potable water
Red line: How I would like the potable water to look
I have diveded the pipe up in to 5 meter segments so that the slope will adjust in between. But I cannot make it work and I have been trying for 3 hours now...
Can you please tell me what rules I need to apply?
Right now I'm using the following:
Structures (null): Nu rules applied
Pipes: Cover only (min 1.2m and max 2 m)
I hope someone can help!
Thank you in advance and all the best!
Mikkel
edit: I'm btw using C3D 2015.
Simon_Blain
Since you seem to be using a pipe network and not pressure pipe network (which I understand why because the pressure network sucks IMO) I'd guess it's because there might be a non-written minimum 0% slope rules.
As in the pipe will not get a positive slope (upwards slope in flow direction) because of the minimum cover rule.
mhvam06
Thank you for commenting.
Solution:
I changed the minimum slope to -100% and the max slope to 100%. That did the trick!!
Simon_Blain
Good idea, didn't even think of that solution ahah 🙂
